1998 Ford Explorer 1998 Explorer Won't Start
128,000 MILES • 6 CYL • 2WD • AUTOMATIC
BLUEGOOSEV6
My explorer sounds like it is attempting to start, but seems like it isn't getting any gas? I thought it may be out of gas, because it was very low when I last drove. I have since put 2 gallons of gas in it and still nothing. During that time we had a bad freeze, so I thought maybe my gas lines may have froze, so I put HEET in, and still nothing. I have had no problems starting it prior to this. I don't know a whole lot about cars, and I understand it could be a wide range of possibilities. Any suggestions are appreciated.
Feb 2, 2009 at 4:57 AM
RACEFAN966
  • 5,029 POSTS
Ok first we need to know weather or not it has fuel or spark. So if you would first pull a spark plug wire and put a philips screw driver in the end of it and turn the engine over and see if there is spark. If so then put it back and find the shrader valve on the fuel rail and use a small screw driver to depress the valve (now keep in mind it takes 36 psi to make this car run) keep your hands away thats why I say use a screw driver and slightly depress it and see if fuel will try to spray out with good pressure or just trickle out. Let me know what you find and we will go from there.
Feb 2, 2009 at 5:02 AM
