1998 Ford Explorer 1998 explorer loses idle when put in dri
157,000 MILES • 6 CYL • AWD • AUTOMATIC
IIISLACKERIII
Im looking at buying a 1998 explorer. it has a problem with going into drive, it starts fine. if you let the car idle and put it into drive it dies. however
if it is reved to around 2500 and poped into drive quick then it is fine. it has been diven like that 3 times in the last 2 months..is this something easy? ICV? EGR? something that way.
Feb 20, 2010 at 1:22 PM
  • 110,246 POSTS
In my opinion, if it was an easy / cheap fix, the present owner would have fixed it to get the most money from the vehicle. However, that is only my opinion.
Now for the problem, is the check engine light staying on? Do you know if the fuel pump pressure been checked, EGR, TPS, or IAC? Also, when you get it to go, does it have normal power? Finally, when at a normal idle and you put it in gear, does it learch forward and then die?
Feb 21, 2010 at 12:42 PM
IIISLACKERIII
It was a ICV got it for $600 fixed it in 3 mins runs and drives great. $670 car and its worth 3 times that...plus it had a full tank of gas.. :)
Feb 21, 2010 at 1:14 PM
  • 110,246 POSTS
I'm glad you got it fixed. I asked about the IAC which is the idle air control / basically the same as the ICV. Regardless, it sounds like you got a good deal.
Take care and let us know if you have other questions.
Feb 21, 2010 at 11:14 PM
