1998 Ford Explorer
1998 FORD EXPLORER
120,000 MILES • 4 CYL • 4WD • AUTOMATIC
BAZZYB
Hi
My explorer recently has been slipping between gear changes (only between1st and 2nd) and the O/D light has started flashing-could this be the transmission sensor and if so is this easy to repair and where is it located? also will it be ok to still drive until I manage to get the problem fixed?
Thanks
May 11, 2010 at 9:48 AM
Check the transmission fluid condition and level if okay bring it in and have it pressure tested.
May 11, 2010 at 11:47 AM
