1998 Ford Explorer
KGRE1068
  • 1998 FORD EXPLORER
  • 6 CYL
  • 4WD
  • 133,000 MILES
My truck is all of a sudden making a loud reving noise while driving and then my RPM's drop. What is this problem?
Thank you
Kelly
Tuesday, November 11th, 2008 AT 7:55 AM
JNOVACK
  • 723 POSTS
First things to check are the fuel pressure, fuel filter, cam and crank shaft sensors, pcv valve, throdle position sensor, map sensor, and lastly the pcm witch may need a software update
Tuesday, November 11th, 2008 AT 11:48 AM
