Transmission problem
1998 Ford Explorer 6 cyl Four Wheel Drive Automatic
will a transmission from 95 explorer work in a 98 explorer. Both are 4.0 v-6 automatic and 4-wheel drive. Also are the heads interchangable
Monday, February 22nd, 2010 AT 4:28 AM
MECHANIC
We always recommend staying with direct fit parts. Chances are the parts will work, but they change things so often, it is hard to tell if there are different sensor locations, vacuum.
