1997 Ford Explorer will not shift
177,780 MILES • V8 • AWD • AUTOMATIC
WOOGLES
  • 6 POSTS
With the help found here and other online I repair temperature blending door . Got everything put back together Temperature works. But now the car will lnot shift out of Park! Shift lever moves but does not change gears. Un bolted steer column and layed on drivers seat while removing dash. Bolted it all back into place. Cant figure it out. I assume shift cable became disconnected.
May 1, 2010 at 11:37 AM
MERLIN2021
  • 17,250 POSTS
You may have knocked it out of the mounting bracket at the column.
https://images.2carpros.com/forum/automotive_pictures/62217_shifta_2.jpg
Check point 1 and snap it back in... if this is the problem let me know, if not I will send more info.
May 2, 2010 at 2:49 AM
WOOGLES
  • 6 POSTS
May 2, 2010 at 3:15 AM
WOOGLES
  • 6 POSTS
That was it!! Thanks! I will use you in the future!!
May 2, 2010 at 3:16 AM
MERLIN2021
  • 17,250 POSTS
Your welcome.
May 2, 2010 at 4:28 AM
