1997 Ford Explorer Whining noice
  • 1997 FORD EXPLORER
  • V8
  • AWD
  • 164,000 MILES
There is a whining noise that seems to be coming from the area of the Cam sensor. Kicks in at over 1500rpm and worse when accelarates. The noise is even worse when in neutral and the parking brake is on. Makes the noise with the belt off so it can't be the pullys, water pump or alternator. Does not seem to be transmission related. Any ideas?
Thursday, April 22nd, 2010 AT 10:52 AM
  • 109,885 POSTS
If you hear it with the belt off, either the harmonic balancer is hitting something or it is coming from the transmission.
Thursday, April 22nd, 2010 AT 1:52 PM
Turns out it was the camshaft synchronizer.
Friday, April 23rd, 2010 AT 3:09 PM
  • 109,885 POSTS
I'm glad you got it fixed. Take care and thanks for usin 2carpros. Com.
Friday, April 23rd, 2010 AT 5:20 PM
