Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine Cooling
Radiator
Leak
1997 Ford Explorer where is coolant going
1997 FORD EXPLORER
16,000 MILES • 6 CYL • 4WD • AUTOMATIC
TNEXPLORER
MEMBER
1 POST
where is coolant from radiator going
I have to fill it every day with no visible leaks
Feb 6, 2009 at 1:56 AM
BMRFIXIT
Experienced Mechanic
Suspect heads
Need to do a coolant pressure test
Check intake manifold gasket
Check head gasket
Feb 6, 2009 at 2:06 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Check engine light
