Dear Friends,
Kindly put some light on the issue in my 1997 Ford Explorer. It was not dropping water unless I went to a cold place. below 70 degree
I parked the car in the night and in the morning when I came to the car I saw radiator water leak under the engine.
I poured water in the radiator.
One drop after 1-3 second was dropping.
I started the engine and run it for 15-20 minutes. after Engine warmed up and temp gauge reaches normal rage, The water drop stopped.
Again next night when I parked the car and engine got cold below 70degree, water again started dropping. As soon as I warmed up the engine the leak stopped.
Experts Kindly guide me what can be the issue.
Thanks.
Thanks.
Sep 9, 2009 at 4:36 PM
