1997 Ford Explorer Water leak
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
RAHKAR
The leak is around the thermostat, which is in a plastic housing toward the back of it by engine where heater hose run through, can't see it all because of air intake manifold, and can't see how to remove it?
Nov 14, 2009 at 12:05 PM
RAHKAR
[quote:e57372769d="rahkar"]Engine Cooling problem
1997 Ford Explorer 6 cyl Two Wheel Drive Automatic 150000 miles
The leak is around the thermostat, which is in a plastic housing toward the back of it by engine where heater hose run through, can't see it all because of air intake manifold, and can't see how to remove it?[/quote:e57372769d]
Nov 14, 2009 at 12:08 PM
