1997 Ford Explorer turn signal
SCOOTERATM
Electrical problem
1997 Ford Explorer V6 Four Wheel Drive Automatic 88000 miles
The left turn signal generally does not work. If I play with the 'signal lever' (move it forward and down), I can sometimes get the left signal lights to work. Right signal and emerg. flashing lights (both sides) work fine. Got any ideas??? Thanks
Dec 8, 2007 at 7:46 AM
FLEXY5
  • 512 POSTS
the turn signal switch is part of what is known as the multi-function switch. it is common for them to go bad. But they are fairly easy to replace.
Dec 8, 2007 at 8:20 AM
  • 55,851 POSTS
Yep, I agree, here is how to change the turn signal switch out. Check out the images (below). Let us know if you need anything else.
Jul 22, 2024 at 7:21 AM
