1997 Ford Explorer Truck wont start
MPACK11
  • 1997 FORD EXPLORER
  • 6 CYL
  • AWD
  • 145,000 MILES
My truck wont start I checked the coil, No spark, checked power to coil, Got power, Got new coil, no spark, Good fuel pressure? Still wont start?
Thursday, April 24th, 2008 AT 8:34 PM
  • 31,937 POSTS
Hi there,
have you done a diagnostic check yet? Check foe any set fault codes, you may have a faulty crank angle or cam angle sensor (if fitted) do this first.
Mark (mhpautos)
Friday, April 25th, 2008 AT 5:25 AM
AMANDA CAMBRIDGE
Im having the same problem. We think it might be either the cam sensor or the crank sensor. Even the timing chain. Im tryin to get an answer back as well.
Uote="Mpack11"]Electrical problem
1997 Ford Explorer 6 cyl All Wheel Drive Automatic 145000 miles
My truck wont start I checked the coil, No spark, checked power to coil, Got power, Got new coil, no spark, Good fuel pressure? Still wont start?[/Quote]
Friday, July 4th, 2008 AT 9:12 AM
