1997 Ford Explorer total transmission failure.
114,000 MILES • 6 CYL • 4WD • AUTOMATIC
JULESOO3
I was driving along when I suddenly lost transmission altogether - engine then cut and would not start again.
It had been making a strange whining noise at a pitch relative to gear and speed for 24hrs leading up to breakdown. There had been a couple of occasions in the previous 2 months when the gear did not change down for a moment. Both occasions happened at the same place - just coming down a slip road to a round-a-bout from motorway speeds to low speeds.
Jul 2, 2010 at 11:51 PM
  • 110,251 POSTS
Has the check engine light come on? Is the trans fluid full and clean? Will the engine start now?
Jul 4, 2010 at 5:54 AM
