1997 Ford Explorer temp gauge is pegged hot but motor is co
ERNHDTFAN1
  • 1997 FORD EXPLORER
  • 6 CYL
  • 140,000 MILES
The temperatur gauge in my explorer is pegged all the way hot, but the engine is running cool. Do I replace the thermostat or is it a sensor of some sort?
Thursday, May 1st, 2008 AT 1:30 PM
MUSTANG87
  • 261 POSTS
If the truck is not over heating and the temp is high u should try a new temperature switch. Also what makes those newer vehicles read wrong is if u just use water in your cooling system and not atifreeze. You should use half and half or even better 90 perceent antifreeze and 10 water thats what I do. If none of this works for u your temp guage is bad.U can also use a universal temp guage that is sold at auto parts stores and this way u wont have to buy the whole cluster and save money, it connects to the original temp switch, only do this if your guage is bad and u wanna save money. Go to www. Kragen. Com look at the temp guages and temp switches. Good luck. By the way the temp switch is on the lower intake
Thursday, May 1st, 2008 AT 4:44 PM
