1997 Ford Explorer tdc
1997 FORD EXPLORER
DTEACH04
  • 5 POSTS
Engine Mechanical problem
1997 Ford Explorer V8 All Wheel Drive Automatic
to set cam sensor it says go to notch in pulley. do i go to 0 degree or to notch on other side of pulley (about 180 degrees from 0) for top dead center.
Mar 16, 2010 at 8:13 PM
OBXAUTOMEDIC
  • CERTIFIED EXPERT
  • 3,711 POSTS
0 Degrees is TDC if you use the other notch you will be 180 Degrees out. You will also need to make sure you are on the Compression Stroke. If not sure you can remove the Number 1 Plug and have someone just hit the key and bump the engine over. You probably want to Disconnect the Coil(s) first so the engine doesn't start accidentally. You will know when the #1 cylinder is around TDC when you hear or feel air rush out the plug hole. Then just make sure the mark is at 0 degrees.
Mar 16, 2010 at 8:49 PM
DTEACH04
  • 5 POSTS
we did that . and truck wont start . truck ran with no sensor and check engine light on.
Mar 17, 2010 at 9:48 AM
DTEACH04
  • 5 POSTS
thanks for assuring me that i wasnt crazy. thought i had tdc but wondered if truck had something weird.
Mar 18, 2010 at 2:53 PM
DTEACH04
  • 5 POSTS
truck running . human error. (me)
Mar 18, 2010 at 2:55 PM
OBXAUTOMEDIC
  • CERTIFIED EXPERT
  • 3,711 POSTS
Sorry, computer crashed the 17th just got it up and running again.
So, your truck is all fixed?
Mar 18, 2010 at 5:58 PM
DTEACH04
  • 5 POSTS
yes thanks. cleared codes now need nys inspection. how many miles to clear sensors?
Mar 19, 2010 at 1:43 PM
OBXAUTOMEDIC
  • CERTIFIED EXPERT
  • 3,711 POSTS
Not quite sure what you mean by "how many miles to clear sensors?". If you cleared the codes then engine light should be off.
If talking about making sure it was sensor and how long it would take for light to come back on, it could be a couple hours of driving or a couple days of on and off driving or even a month. However, as long as light is off and you have no codes pending you should be good for inspection.
Mar 20, 2010 at 7:00 AM
DTEACH04
  • 5 POSTS
showed three sensors not reset at inspec. had to drive around a little. everything reset fine good for another year thanks.
Mar 23, 2010 at 11:45 PM
