1997 Ford Explorer Starting
1997 FORD EXPLORER
PETLAURA
Engine Mechanical problem
1997 Ford Explorer V8 Two Wheel Drive Automatic
My 1997 Explorer won't crank on cold mornings, after the weather warms up, it will crank. We have replaced the crank sensor, but it still does it.
Dec 22, 2009 at 8:09 AM
  • 110,240 POSTS
Has the check engine light come on? Does the starter work? Have you checked for spark and fuel top the engine when this happens? Have you ever tried using starting fluid to start it when this happens?
Dec 22, 2009 at 11:34 PM
PETLAURA
The check engine light does not come on and everything else you mentioned has been checked, it only happens when it's cold outside. We were told to check the ABS and EEC fuses maybe.
Dec 22, 2009 at 11:44 PM
