1997 Ford Explorer squeaking
135,000 MILES • 6 CYL • 2WD • AUTOMATIC
CSAPP
My vehicle has a lot of squeaking coming from the front suspension. I've noticed it seems to be a problem for many of the Ford SUV's that was produced around the same year as mine. I can't seem to pinpoint the specific parts causing the noise. What parts should I replace to remedy the problem?
Jan 6, 2008 at 7:55 AM
ARTMANG
  • 61 POSTS
just get it lubed
Jan 6, 2008 at 11:19 AM
CSAPP
I have already lubed it several times
Jan 8, 2008 at 11:54 PM
ALEX7772006
  • 17 POSTS
is the suspension squels when you go over speed bumps and that kind stuff if so then i had the same problem on 1996 explorer
i replace the rubber things that between suspension and the body and it fixed my squeling
Jan 12, 2008 at 5:29 PM
