1997 Ford Explorer popping in front end
1997 FORD EXPLORER
123,000 MILES • 6 CYL • 4WD • AUTOMATIC
TONY MOODY
i have a popping in the front of my 1997 explorer. I had it aliened recently and bushings put in ( also replaced shocks ) same problem. It does it when you hit a bump in the road. The mechanic that fixed the bushings said everything looked good. What might be the problem ?
Feb 12, 2008 at 9:37 AM
MASTERTECHTIM
  • 4,750 POSTS
i would check the sway bar bushings and links. it will sound just like a bad shock. hope this helps
Feb 12, 2008 at 10:00 AM
