1997 Ford Explorer OVERDRIVE
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
MISS 95
HELLO I HAVE A 1997 FORD EXPLORER I JUST PURCHASED FROM A FRIEND I JUST WANTED TO KNOW DO I ALWAYS HAVE TO MAKE SURE THE OVERDRIVE/OFF LIGHT IS ON THE DASH BEFORE DRIVING. SHE TOLD ME IF I DIDNT HIT THE OVERDRIVE BUTTON AND SEE IT SAY OFF THAT I WILL BURN MORE GAS AND THE CAR WOULD DRIVE FUNNY IS THAT TRUE.THIS IS MY FIRST TIME WITH A MIDSIZE SUV
Aug 6, 2008 at 5:29 AM
MUSTANG87
  • 261 POSTS
if the od light is on it means your gonna drive the truck in 3 speeds only and your truck has 4 and yes it will burn more gas on highway because engine will be on higher rpm.overdrive is the 4rth gear .u can use overdrive off when your climbing steep hills.i would recommend u use it in regular drive for evry day driving /no od light. ok i dont know why ur friend said to drive it with od light on witch means 3speed only.you must drive it with over drive on witch means you wont see the od light on your dash.you friend is backwards lol.you will burn lots of gas with od off.maybe your friend is trying to gip u of the truck?maybe it has bad trans?thats why shes telling u to use it with od light on?because trans is slipping on fourth?lol i dont know but be careful.must use it with out light on.good luck.
Aug 6, 2008 at 9:30 AM
