Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Oil Pump
1997 Ford Explorer oil pump location
1997 FORD EXPLORER
11,000 MILES • V8 • AWD • AUTOMATIC
GRASSMASTER
MEMBER
1 POST
where is the oil pump located
Jan 26, 2008 at 5:52 AM
FLEXY5
Experienced Mechanic
Is this the 5.0? You listed as a V8? If this is correct the oil pump is in the iol pan, bolted to the block. But you will have to loft or remove the engine to get to it. If you have any other qestions, feel free to ask.
Dave
Jan 26, 2008 at 12:49 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
