1997 Ford Explorer oil burn
94,600 MILES • 6 CYL • 4WD • AUTOMATIC
JUSTINF89
  • 22 POSTS
In my ford service manual, it states that it is normal for the engine to burn about a quart of oil every 900 miles. This seems a bit excessive to me but I've never owned a ford and haven't had this one long enough to see this. Is this just in the specs where thats the max it can burn before it becomes a problem or is normal for a good running engine to burn a quart so often like this? Thanks.
Apr 7, 2010 at 3:08 PM
  • 110,248 POSTS
That is a good question. Some cars will never use a drop of oil between oil changes and others a quart every 1K or so seems normal. If you are using that much, don't be to concerned. Presently, I use a qt every 500 miles, but on an engine with 220K, it's acceptable.
Apr 8, 2010 at 4:19 AM
JUSTINF89
  • 22 POSTS
It burns about a quart every 1500 miles, but only having 94k miles, I thought it was a bit on the high side; I guess not. I heard that high mileage oil helps with this a little bit but I guess if this is normal, it may not. Thanks for the info.
Apr 9, 2010 at 10:54 AM
  • 110,248 POSTS
That is actually really good. I know Chrysler considers a quart every 1K as normal when the car is new.
Apr 9, 2010 at 12:23 PM
