HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Climate Control
Heater
Not Working
1997 Ford Explorer No heat!
ROOFER37
MEMBER
1997 FORD EXPLORER
V8
AWD
AUTOMATIC
122,300 MILES
Heater stopped working and I replaced the thermostat to solve the problem, but it still doesn't put out any heat.
Thursday, January 17th, 2008 AT 10:42 AM
MASTERTECHTIM
MECHANIC
DOES YOUR BLOWER MOTOR WORK? WHEN YOU CHANGED THE T STAT, WAS THE COOLANT BROWN AND MUDDY? CHECK BACK TO US.
SPONSORED LINKS
Thursday, January 17th, 2008 AT 10:48 AM
Please
login
or
register
to post a reply.
Related Heater Not Working Content
Heater Will Not Work?
The Heat Doesn't Work, I Changed The Thermostat And Still Doesn't Work. But The 2 Hoses Going To Fire Wall Are Hot But The Blower...
Asked by
melymat
1 IMAGE
1997
FORD EXPLORER
VIDEO
Heater Not Working
Instructional repair video
GUIDE
Heater Not Working
Step 1 - A heater cannot operate unless the engine is full of coolant/antifreeze. If coolant level is low check the system for leaks.
My Heater Is Not Working - Blows Cold Air?
Heater Problem 2003 Ford Explorer 6 Cyl Two Wheel Drive Automatic Heater Blows Cold Air And Makes Ticking Sound
Asked by
dalmationmom3
9 IMAGES
2003
FORD EXPLORER
Heater Not Getting Hot?
So I Replaced The Thermostat In My 99 Ford Explorer Because The Heat Wasn't Getting Hot Just Warm. The Hoses Going Into The Firewall Top...
Asked by
AdamClev
1999
FORD EXPLORER
Heater Not Working?
Hi- Maybe You Could Help Me Out. This Pasty Winter My Vehicle Heater Has Been Coming Out Cold. But At Times After A Few Minutes And...
Asked by
marioBjunior
2 IMAGES
2004
FORD EXPLORER
No Heater Operation?
My Heater Is Blowing Cold Air, Is This The Heater Box Or Door, I Had It Look At, One Repair Shop, Said Its The Temp Door, And I Need...
Asked by
JAMES F. BROWN JR
1 IMAGE
1998
FORD EXPLORER
VIEW MORE
SPONSORED LINKS
Heater Not Working
Blend Door Actuator Replacement
Online car repair manuals
