Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Suspension
Ball Joint
Replace/Remove
1997 Ford Explorer lower ball joints
1997 FORD EXPLORER
180,000 MILES • 6 CYL • 4WD • AUTOMATIC
BILLKANGAS
MEMBER
can the lower ball joints be replaced without replacing the control arms?
Jan 30, 2010 at 6:45 AM
BLUELIGHTNIN6
Experienced Mechanic
The lower ball joints and bushings are an integral part of the lower control arm, they can only be replaced as an assembly.
Jan 30, 2010 at 6:52 AM
SCOTTY DEE
Blue is on the money Bill. You can buy a MOOG chassis part to replace it with and that is the only way to travel!
Jan 30, 2010 at 8:42 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
