Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Drivetrain
Transmission
Gear Selector
Loose
1997 Ford Explorer loose gearshift
1997 FORD EXPLORER
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
ZICHAR
MEMBER
1 POST
have some play in the prndl sometimes won't start until move the gearshift around what could be the cause
Nov 10, 2008 at 12:50 AM
BMRFIXIT
Experienced Mechanic
Check and adjust shift cable
check shifter handle
if all OK suspect neutral safety switch
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 10, 2008 at 10:38 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
