1997 Ford Explorer Ignition Misfires
RKRUSZKA
Engine Performance problem
1997 Ford Explorer 4 cyl Two Wheel Drive Automatic
I have a pushrod 4 cyl 97 Ford Explorer with 154,000 miles. It's got a rough idle and very sluggish acceleration. Replaced plugs and wires after I got a P0171 code on it, then drove it for a week and still got the same performance. Just got the P0171 code with the same misfires - 1,3, and 6. Air filter's clean, no buildup in the intake manifold, no vacuum leaks that I can tell. Should I replace the coil? Any other ideas?
Mar 21, 2009 at 7:07 AM
F4I_GUY
  • 3,302 POSTS
https://www.2carpros.com/trouble_codes/obd2
Here is a link explaining that code and goes through a diagnostic procedure.
Replacing an ignition coil is not going to solve this, you may have a dirty MAF sensor that needs to be cleaned or replaced.
Hope this helps.
Dec 21, 2020 at 3:29 AM
