1997 Ford Explorer howling noise from resevoir
C2MAN
Noises problem
1997 Ford Explorer 4 cyl Two Wheel Drive Manual 105k miles
When the engine is hot (normal temp) a howling sound comes from the resevoir this only happens when the car is up tp temp
Jun 14, 2009 at 2:19 AM
TECHS IN
  • 14 POSTS
Normally a noise coming from the reservoir indicates excessive pressure from water temperature. I would suggest you use a temperature thermometer to check the actual temperature of the water in the reservoir. Please keep in mind safety at all time.
Jun 15, 2009 at 7:13 PM
