1997 Ford Explorer help
JAMESADAIR
Electrical problem
1997 Ford Explorer Two Wheel Drive Automatic
i bought a 1997 ford explorer,alternator was bad,i changed it and put a new battery in.now the new alternator will not charge the battery.i have checked the fuse's and none are blow.i took the new alternator off and had it tested,autozone said i was good.please help
Feb 8, 2010 at 5:40 AM
  • 110,248 POSTS
If the alt is good and the battery is good, there is a fuseable link between the alt and the battery. Chances are that is bad.
Feb 11, 2010 at 5:23 AM
