Whenever the headlights are turned either by switch or twilight sensor, only the parking lights come one, the high beams work when you hold back the lever as to flash, but do not work when you press it forward for them to stay on, and regular beam does not come on. Sometimes when you shake the lever back and forth, something clicks and the lights come on. I have checked the fuses and the relay fuses under the hood and also have replaced the headlight switch itself and the problem still remains, what could be causing this?
Oct 9, 2008 at 9:39 AM
