Right headlight is out
1997 FORD EXPLORER
146,000 MILES • V8 • AWD • AUTOMATIC
RUSTYMILLCREEK
Right headlight out, in cabin and under hood fuses all are good, it is not the bulb, putting power to the outbound side of the in cabin left head light fuse lights the light, the same does not work for the right head light. Fog lights also do not work. I am not getting a head light out message.
Dec 19, 2008 at 8:19 PM
DAVE H
  • 13,384 POSTS
check fuse # 8 in underhood fuse/relay box and Foglight Relay..In auxiliary relay box No. 2. power feed for right low beam goes through these .. is the high beam working ??
May 10, 2021 at 1:24 PM
RUSTYMILLCREEK
Solved, it was the light out module, thx
