On the way to work my truck seemed to be slipping inot neutral. After finally getting to work I smelled burning and there was smoke under the hood. When I lifted the hood it was hissing and looked like chocolate milk had exploded under the hood and the same brownish fluid began puddling quicky under the right front headlight on the ground. Is this most likely my head gasket? If so, is this a pricey repair?
Mar 29, 2008 at 1:41 AM
