1997 Ford Explorer fuel system problem
120,000 MILES • 6 CYL • 4WD • MANUAL
MUSTBAFORD
codes 0171,0174,1131,1151 came up
What is 1151 02 sensor heater circuit signal intermittent bank 2 sensor 1 ???
and is there any to test the fuel pump?
Aug 30, 2009 at 9:55 AM
  • 110,251 POSTS
The code identifies there is either a bad sensor or there could be an electrical problem to that O2 sensor.
Here is a how to for checking fuel pump pressure:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know if it helps. Also, if you don't have a gauge, many parts stores will lend or rent them.
Sep 1, 2009 at 1:06 PM
