REMOVAL AND INSTALLATION
Remove the upper intake engine inlet plenum.
Disconnect the fuel lines.
Warning: Refer to Service Precautions/Technician Safety Information before disconnecting fuel system components.
Remove the fuel injection supply manifold.
Remove the fuel injectors from the fuel injection supply manifold.
Inspect and replace the two O-rings from each fuel injector if necessary.
NOTE: Lubricate new O-rings with engine oil.
To install, reverse the removal procedure.
Sep 16, 2010 at 10:32 PM
