1997 Ford Explorer fuel injectors
250,000 MILES • 6 CYL • 4WD • AUTOMATIC
ASMITH28
i need to know how to install fuel injectors
Sep 16, 2010 at 7:02 PM
  • 75,988 POSTS
REMOVAL AND INSTALLATION Remove the upper intake engine inlet plenum. Disconnect the fuel lines. Warning: Refer to Service Precautions/Technician Safety Information before disconnecting fuel system components. Remove the fuel injection supply manifold.
https://images.2carpros.com/forum/automotive_pictures/12900_i1_3.gif
Remove the fuel injectors from the fuel injection supply manifold.
https://images.2carpros.com/forum/automotive_pictures/12900_i2_4.gif
Inspect and replace the two O-rings from each fuel injector if necessary. NOTE: Lubricate new O-rings with engine oil. To install, reverse the removal procedure.
Sep 16, 2010 at 10:32 PM
