Swapping out the relays had no effect -- However, I was able to get the washer to work intermittently although infrequently-- pushing in and holding the washer button while also putting just a little pressure on the control handle (up/down or in an out) got the washers to come on -- it worked when initiated with the wipers in the off position or the run position -- but it did not work all the time, and often took multiple tries with the button held in continuously for 10-15 seconds at a time before it worked, and again not everytime.
It appears as though it is a bad control column handle -- do you agree
quote="bluelightnin6"]Hello
Thanks for the donation
It sounds like you may have a faulty switch. You said that you checked the fuses, did you check the relays as well? If not, one of the relays ( believe your vehicle has 2 relays for washer) is sticking or has become faulty. You can use the horn or a/c relay from the relay and fuse box near the battery to swap out the relay for easy testing. If the relay is good then suspect faulty control switch.
Post your results and I will follow up.
Thanks for using 2carpros.com![/quote]
Jan 4, 2009 at 8:33 AM
