Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Engine
Symptoms
Not Cranking Over
1997 Ford Explorer engine wont crank
1997 FORD EXPLORER
128,000 MILES • 6 CYL • 4WD • AUTOMATIC
EX-PLORER
MEMBER
1 POST
Battery is fully charged, When key is turned Dash lights dim, relay clicks but starter motor doesnt crank.
Sep 6, 2009 at 12:31 PM
Experienced Mechanic
Load test the battery if okay -start checking the starter, starter relay, neutral safety switch and ignition switch.
Sep 6, 2009 at 4:41 PM
EX-PLORER
MEMBER
1 POST
seems that it is the red wire going to the starter itself. Trouble is its a 4 x4 and I can get at it. I dont have a ramp or Pit.
I wiggled the wire and it started, I suspect there is a short somewhere on it .
Sep 7, 2009 at 12:59 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
