1997 Ford Explorer eNGINE OIL TEMP SENSOR ERROR
RONDA92114
Computer problem
1997 Ford Explorer 4 cyl Four Wheel Drive Automatic
JUST HAD MY ENGINE REDONE FROM CRACKED HEADS... AND ALL GUAGES ARE NORMALL . AFTER 50 MILES THE CHECK ENGINE LIGHT AND CHECK GUAGE LIGHTS COME ON BUT ALL LOOKS GOOD...
CHECK SYSTEM BUTTON AND OIL LEVEL OK, OIL LIFE OKAY, THEN MESSAGE SAYS "ENGINE OIL TEMPERATURE SENSOR ERROR".. IS MY ENGINE GONNA BLOW UP OR DOES SOMETHING JUST NEED TO BE RESET
Jul 9, 2010 at 6:39 PM
  • 110,248 POSTS
It just sounds like the sensor is bad. Make sure the engine isn't overheating or anything.
Jul 10, 2010 at 5:15 AM
