1997 Ford Explorer engine light
136,000 MILES • 6 CYL • 4WD • AUTOMATIC
STEADYHAND
  • 30 POSTS
Hi, my 97 explorer has a check engine light on. I had the codes ran and it came up as P0131 and P0153. I was told it was reading Bank 1 sensor 1 for both codes. I had the O2 sensor changed for Bank 1 Sensor 1 and disconnected the battery to reset the codes but the light is still staying on.
The engine lopes at times or will idle really low. Sometimes I start to think it might die but the RPM's usually goes back up to a normal idle.
Any ideas what this could be? What should I start checking?
May 27, 2010 at 12:12 PM
  • 110,251 POSTS
Check the wiring to the sensor and its condition. That is a low voltage reading / slow response.
May 28, 2010 at 6:46 AM
