1997 Ford Explorer Engine Bogs and or Stalls On Hot Days
217,000 MILES • 6 CYL • 4WD • AUTOMATIC
JIMMY KAY
All coolants and oils are all to correct levels. When the temps are higher then 95 degrees the engine runs like it needs a major major Tune Up. I have recently givin the truck a tune up, NOT the PROBLEM. My ? could fuel injected engine get Vapor Lock @ High Temps. Or is there a posibilty that the Mass Airflow Sensor can't handle extreme heat and needs to be changed?
Jul 7, 2008 at 1:24 PM
KHLOW2008
  • 41,812 POSTS
Hi Jimmy ,
Is the check engine light showing while running the engine?
If no, you would need to run a diagnostic on all the components to find out which is not performing to specs.
As it is related to the ambient temp, I would suspect the Intake Air Temperatue sensor.
Jul 9, 2008 at 2:54 AM
