1997 Ford Explorer Electronic Air Temperature Control Modul
140,000 MILES • 6 CYL • 4WD • AUTOMATIC
COLIN1
The Heater is on all the time will not shut off. Temperature control on dash checks out okay and I have installed new heater valve. there is a module between the two. Where is it and could you provide a diagram of its location and some instruction on the best way to get to it.
Oct 4, 2009 at 8:39 AM
KHLOW2008
  • 41,812 POSTS
Hi colin1,
Is your vehicle equipped with manual or auto HVAC?
Do you mean you are not able to control the heater temperature?
Oct 5, 2009 at 7:56 AM
