1997 Ford Explorer door panels
SID-A
Interior problem
1997 Ford Explorer V8 All Wheel Drive Automatic
how do i remove drivers side door panel
Feb 20, 2010 at 6:28 AM
  • 110,248 POSTS
Remove the arm rest and any screws that you can find on it. After that, you will seperate the panel from the door. They are attached by plastic clips and will pull apart. However, they can break. There is actually a special tool that is made to seperate them.
Feb 21, 2010 at 12:54 PM
