1997 Ford Explorer Door Locks
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
OBTR312
Doors will not lock from anywhere other than rear lock/unlock button by rear cargo hatch including key fob. will unlock from all positions including key fob.
Jun 17, 2009 at 1:27 AM
GORDDON123
[quote:4630452147="obtr312"]Electrical problem
1997 Ford Explorer 6 cyl Four Wheel Drive Automatic 200000 miles
Doors will not lock from anywhere other than rear lock/unlock button by rear cargo hatch including key fob. will unlock from all positions including key fob.[/quote:4630452147]
I just finished fixing the same problem. The answer is a bad connection. You'll find it under the rear driver's side seat. I took off the whole trim panel that covers the car jack (the big one not the hatch in it). Also removed the small back seat. You'll need to locate a pink wire with a yellow stripe and find where it branches off (close to where it gets to the outside edge of the vehicle and makes a 90 degree corner the front). At this point I found some corrosion. Cut the connection, cut out the corroded section and re-splice. If you have questions email me gohelminen@hotmail.com I won't respond here I'll probably never check this
Aug 1, 2009 at 10:23 AM
