Electrical problem
1997 Ford Explorer 6 cyl Automatic 120000 miles
When the dashboard light is on, the RPM and the battery monitor display are barely lit up. The rest of the dashboard has light. I checked the fuses and do not see any fuse that appears to be broken. Which fuses do I need to change out for new ones or is there something else I need to check?
Feb 2, 2009 at 12:18 PM
