1997 Ford Explorer cranking
15,000 MILES • 6 CYL • 2WD • AUTOMATIC
LINDA NIXON
Vehicle cranks up and runs but when your turn it off it won't crank back up until it sits for a little while.
Jan 3, 2010 at 9:45 AM
  • 75,988 POSTS
Do below to determine if it's a fuel or spark problem:
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jan 3, 2010 at 11:36 AM
