1997 Ford Explorer code p0136
23,000 MILES • 6 CYL • 4WD • AUTOMATIC
GPM1
The 4.0 6 cyl engine has 2 converters and 4 oxygen sensors. 1 before each converter and 1 after each converter. The error code reads to replace the 2nd sensor on bank 1. Which exhaust pipe is bank 1 ? Is the second sensor the one after the converter?
May 2, 2010 at 8:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
bank 1 is passenger side , sensor 2 is behind converter.
May 2, 2010 at 8:24 AM
