1997 Ford Explorer clutch will not disengage
136,000 MILES • 6 CYL • 4WD • MANUAL
GHOST572
replaced with new clutch assemply and slave, did not do master. Still having problems with the clutch not disengaging, in first with clutch petal to the floor with no brake the car will creep forward.
Mar 25, 2010 at 1:00 PM
  • 75,988 POSTS
Rebleed it again and check the master cylinder if its leaking internally and also check the free play and pedal height
Mar 25, 2010 at 3:30 PM
