1997 Ford Explorer clutch
1997 FORD EXPLORER
150,000 MILES • 6 CYL • 4WD • MANUAL
JASON WILLAN
new clutch fitted 15 months ago . Clutch slipping???.
no drive . roll car forward drive again top speed 50 kph . at 3500 rpm. can you help
Apr 5, 2008 at 10:09 PM
  • 31,937 POSTS
if the clutch is slipping , there is a problem with the pressure plate, it may have a cracked diaphragm ore a broken pivot ring, you will have to remove and inspect for damage.
Mark (mhpautos)
Apr 6, 2008 at 12:20 AM
