1997 Ford Explorer clanging noises
151,200 MILES • 6 CYL • AWD • AUTOMATIC
KITTENODAY
when I hit bumps in the road or the road is rough and when I turn corners I get a clanging noise from underneath the car. Also the O/D off & 4WD low lights flash a few times. Some times the lights will just flash.
Can you please help me
thank you
Aug 8, 2008 at 4:08 PM
BMRFIXIT
  • 19,053 POSTS
CHECK RADIUS ARM BUSHINGS
CHECK FRONT END BALL JOINT AND LINKS
FLASHING OD U NEED TO CHECK THE TRANNY FOR CODES
Aug 8, 2008 at 6:10 PM
