1997 Ford Explorer checking it out
126,000 MILES • 6 CYL • 4WD • MANUAL
ANDYFLAHERTY
okay so I have a couple questions for you, on my explorer is the brake and clutch reservior the same thing so I know where to put fluids in for the clutch and also how do I check the transmission fluid, reason for me asking this is because, when the transmission warms up, it kinda jumps a little bit in 1st through 3rd gear, just want to check things out!
Dec 4, 2008 at 3:49 AM
BMRFIXIT
  • 19,053 POSTS
Brake fluid is used for clutch fluid
u need not to add any unless u have a leak
if very low with no leak
suspect worn clutch and pressure plate
good luck
Dec 4, 2008 at 10:47 AM
