1997 Ford Explorer Check engine light on
102,000 MILES • V8 • AWD • AUTOMATIC
FDMY97
The check engine light is on and I just found out by my mechanic that the #6 and #7 cylinders are not firing. My fiance was driving it and noticed some white smoke coming out of the tailpipe when the check engine light started blinking. The check engine light has been on for 3-5 days. What are the possible diagnosis' for this situation? I don't know what the engine codes for the check engine light are right now.
Mar 25, 2009 at 9:01 AM
2CARPRO JACK
  • 11,533 POSTS
From what you describe it may have blown the head gasket between 6 & 7. This would explain the white smoke adn those two not firing.Do a compression test on those 2 then another few for comparison
Mar 25, 2009 at 9:45 AM
FDMY97
[quote:23ec2c2320="2CarPro Jack"]From what you describe it may have blown the head gasket between 6 & 7. This would explain the white smoke adn those two not firing.Do a compression test on those 2 then another few for comparison[/quote:23ec2c2320]
Thanks for the input, I definitely will follow up with my mechanic with this.
Mar 25, 2009 at 9:52 AM
