Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Warning Lights
Check Engine Light
1997 Ford Explorer check engine light bulb replacement
1997 FORD EXPLORER
145,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIGDADDYBILL41
MEMBER
1 POST
How much of the dash has to be removed to replace the check engine light/service engine bulb for replacement?
Sep 1, 2009 at 9:32 AM
BLUELIGHTNIN6
Experienced Mechanic
remove the instrument panel by following directions below in order to replace your vehicle's check engine lamp bulb.
Sep 1, 2009 at 3:59 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
